- Jan 2, 2010
- 2,525
Hey, any help with this is greatly appreciated
I have a 4r70w behind a fuel injected 5.0.
The trans has probably about 2,000 or less-miles on it .
Has worked great for 2 years no problems at all.fluid level is where it supposed to be.
The other day I back it out of the garage and drive to the end of the street, parked it back in the garage and the trans would still be cold, I drove it about 5 minutes. Shut it off went in the house
came back out about about 20 minutes later, good size puddle of very red Mercon v fluid on the floor. Thought a cooling line was leaking, but it was actually coming from the dip stick tube. Cleaned up the mess, then started the motor you could hear the air pressure coming from the dip stick tube opened it and a large amount of fluid burped out and eventually went down. The the trans is still cold at this point.
I drove it the day before this about 30 miles without an issue.
So now you am thinking it’s the vent on the trans, can those clog that quick all of a sudden, to cause this?
Any ideas are appreciated
