4r70w Fluid
BruiserOutdoors
I asked the shop who rebuilt a 4r70w for me what fluid to run. Surprisingly he said Mercon LV. Everything I've seen online said Mercon V for this era of 4r70w. I wonder if its due to the upgraded parts (billet drum, etcc...).
Thoughts?
If the shop is giving you any warranty on the transmission, use the fluid they said to use.
Normally it would be Mercon, but if they want LV, use LV. Don't know what they did inside. I don't know your transmission builder to ask them.
BruiserOutdoors
BruiserOutdoors
I don't recall much of a warranty, it has been sitting for several years. From my research, mercon LV is thinner.
BruiserOutdoors
BruiserOutdoors
4R70W’s used Mercon V, but maybe he installed something that requires the LV. I think I’d ask him again.
He said there was a Ford TSB stating that LV was superior and has great properties for heat and expansion. I never found that TSB.
Tempted to stick with Mercon V...
rocknhorse76
Bronco owner since 1993 💪🏻
Central WA
I know that the two fluids are incompatible with each other, so stick with one or the other. I run Mercon V in my 4R and LV in the 6R that is in my F-150.
RM70
Athens, AL
Ford changed everything to LV around 09, there was something regarding the 4r75 but not the 4r70.
The 70 and 75 are nearly indentical. The 75 got a very minor bump in line pressure and the heat treatment on the planetary gears is to a harder level.
Did the rebuilder put in a 75 rebuild kit?
