4r70w line routing question
rjrobin2002
Is this chart correct for 4r70w trans line routing?
Lower trans port is hot and runs to top of radiator, then the cooled trans fluid comes out the lower radiator port and re enters the higher port on the transmission?
pcf_mark
I honestly do not think it matters. It is a cooling loop you can start at the bottom or the top. All fluid is going to be exposed to the same liquid coolant either way. Some could argue the hot fluid coming in at the top prevents the hot from rising but that makes little sense since the rising heat would need to warm the entire column of high pressure rapidly moving fluid.
rjrobin2002
rjrobin2002
Seems like that chart makes sense, guess I will follow it. The lower port is hot, so I will do the cooler on the return to the upper port?
