BanditBronco
- Jul 2, 2008
- 690
Question for anyone running a "not stock" engine w/ EDIS swap running the explorer computer controlling the transmission. Say you have a 351w swap running explorer ignition and are using the stock transmission harness along with it. Is the transmission tunable at all? Will it shift like a stock explorer or can you tighten them up? Will it hold 1st and 2nd if you have the shifter in that position?
I am planning on swapping to explorer efi on my 351w with aluminum heads and a cam and am trying to decide if I ditch the stand alone transmission controller while I am at it.
Will the stock computer allow me to throw it in 4 low, go duning and shift between first and second all day running 4-5k rpms?
