On to the next issue. Have an EFI Guy harness and looking to install a Winters shifter. Had no idea that this is going to require draining and dropping the transmission pan. Seems like they could have just designed a bracket to replace the existing one....
Can anyone confirm that the linkage arm in the kit will work with my stock harness connector? As in it will plug into it, and tell the ECM what gear I'm in?
Thank you. Mel
Thank you. Mel
