4x4x2 pitman arm?
jperry1290
I have a stock EB pitman arm that should be ok with my 4x4x2 box, but it will need to be drilled out for my TRO setup. Are there stronger aftermarket pitman arms that someone has used? I figure I could sell my stock pitman and use the money to fund a new one.
There are both heavier stock arms and some pretty stout custom ones as well.
Most of the ones carried by companies like us are dropped arms, which it sounds like you don't need?
A stock full-size truck arm that would have come originally on that box is very beefy. Maybe someone here has one, or you can get one from one of the Bronco vendors in the form of a used one. We might have one around, but they come in irregularly. Driven Auto Parts is a good source of stuff like that.
But check the classifieds here first.
The custom ones are very cool, and are going to be more spendy too. Machined from billet or custom cast, you can often get them in different drops and angles.
And speaking of angles, the disadvantage to the stock full-size arm is that it's angled the opposite of the proper way for a 4x4x2 conversion. It's not caused any trouble for most of us that use them (I have one on my '71), but it would still be better to have the proper orientation if you can find one.
Some members here will remember the fab shops that sell different arms I'm sure.
jperry1290
jperry1290
I already have a stock pitman arm. My TRO is a hiem setup which is why I need to drill the arm
Up to you entirely. I don't see any huge disadvantage to either, but I generally prefer keeping a tapered rod end (vs a spherical rod end, which is what a "Heim" joint is) because you don't have to modify anything, and they are a known reliable piece, that may be easier to find replacements for.
Does your draglink design allow for sourcing a standard rod end for? If so that's the way I'd go.
Where will the lower end of the draglink mount?
Now that's a pitman arm! I like it.
So do they of course, and the price shows it. But looks like you get what you pay for.
I take it that it's angled correctly for a rear-facing EB orientation?
What's the rest of your setup look like? Have we seen images of it here on the forums?
74 Bronco Billy
I have a 74 Bronco that came with a modified F-100 box already on it. I did a TRO set up with this PS box on the inside of the frame. I had to modify my Pittman Arm because the taper was in wrong direction. I need a drop up PA. So, a lot of time on drill press, then a tapered 1 ton GM sleeve from Ruff Stuff was tig welded in. I polished it up, then when I installed it, I did not like the angle it m eff t the drag link. So I heated it up and bent it with a huge crescent wrench. No quenching. Much better geometry in the end.
Sent from my SAMSUNG-SM-G930A using Tapatalk
nvrstuk
PNW
I did almost the same pitman arm mod's as BroncoBilly but I am using a 78-9 Bronco/F150 box...I used the stock Bronco manual pitman arm for the correct length for full steering lock to lock and since my pitman arm is also facing rearward I also had to adjust the "rotation" of the pitman arm for the drag link to attach/droop without restriction. Without rotating or twisting the pitman arm I was limited to just a few inches of droop on the pass side before interference. Using heim joints is the only real difference. Careful heating/cool down is the key. Great pics.
I was looking for custom pitman arm manufacturers but they are rare...
74 Bronco Billy
Try this place in Auburn, Ca.
Wfoconcepts.com
There's another one but it's slipped my mind...CRS, so keep trying GTS.
