4x4x2 Pitman Arm
BoureeOne
Madisonville, La
Ok, I know others must have gone through this. Wrapping up my steering linkage. I have the 4x4x2 box out of a 79 Bronco. I also have the Pitman arm that came with that box. The problem with that arm is that the hole where the drag link connects, is pitched in the wrong direction ( up and towards the drivers side ). To get the drag link ball joint stud to go in that hole, I had to knock it over towards the drivers side to the max it would go. This just seems like it would cause quicker ware. In the pics you will see the 79 Bronco arm next to the stock EB manual steering arm. The EB arm is much smaller. But the hole for the drag link is angled towards the passenger side, like I need. So here are my questions. My rig is going to be street only, with 31x10.5x16 tires. Is the smaller EB manual arm going to be just fine? Also, is there an EB stock power steering arm that is of the bigger thicker style ( like the 79 Bronco Arm ), but also is angled towards the passenger side like the EB stock manual steering arm.
Does everyone who is running the 4x4x2 box use the stock EB manual arm? I have a drop pitman arm, and it is set up like the stock EB manual arm, with the hole angled towards the passenger side. But for my set up, I need to use a flat arm for clearance of my steering stabilizer.
Thanks, Scott
Swerve
I am curious why the '79 Bronco / 4x4x2 pitman arm can't be heated and bent to match the angle of the original pitman arm. It is very common to heat and bend pitman arms and similar in the Hot Rod world. I've had to heat and bend pitman arms and steering arms on early Ford round back spindles many times to get my geometry correct...
sykanr0ng
It is my understanding that the stock EB pitman arm works just fine on a 4x4x2 box.
Yes, the stock manual arm is just fine as was discussed. If you do happen to find a good used power steering arm though, from about '75 and later especially, they are beefier than the manual arms.
But don't lose any sleep over it. The power at the box might be greater than the manual steering was, but your tire size has been used with those arms for 50 years and counting. With very few issues.
Just don't use your steering system's new found power to muscle your way out of being stuck between to boulders and you will probably never brake or bend or mutilate anything.
And as was discussed in your other thread, ALL Early Bronco arms are tilted the correct way. And ALL Early Bronco arms have the same size hole for the sector shaft on the box, so will bolt right on.
You just have to make sure that the upper draglink end is the proper size for whatever tapered hole size you have. The EB arms will all have a smaller tapered hole than any of the later full-size truck arms did.
As you see by your own pic too, the EB arms is shorter. This may or may not be an advantage/detriment in steering feel or performance, but it sure as heck gives you more wiggle room before your parts start hitting each other!
jmangi62
I'm with doghows,I just bolted my manual arm back on and it's fine. :cool:
