5.0 distributor / ECT sensor clearance issues
Projp
The PO assembled most of the motor and I bought it as a roller.. I "think" it is a 89 5.0 mustang motor with explorer dress.
I did get it to fire up for a minute with just a short water temp sender in the ECT hole because that is all I can get to clear. I can't find a way to get the EGT sensor to clear the distributor.
If I rotate the distributor clockwise it comes close to clearing but then the distributor wiring runs into the serpentine idler pulley assembly.
So....Do I need to
Change distributors?
Change the ECT sensor?
Find a different coolant rail?
Relocate the sensor?
What is standard procedure in this case
kempco
Pull the distributor out and rotate it so that the module sticking out of the distributor is facing north south direction.
