Was cruising on Michigan backroads doing around 55 MPH when suddenly there was a loud noise (sounded like metal snapping) then a backfire out the tailpipe. Engine immediately stalled.
Once pulled over to the side of the road, the truck would crank but not start. I found these pieces (small spring, a couple of small sheared metal pins with C-clips, a plastic hole cover and some other shards of broken plastic) on top of the intake manifold. I guessed they came from the distributor, as I’ve seen that hole cover on there before.
Needless to say, got the truck towed home and started some investigation.
Looks like the distributor‘s mechanical advance self destructed.
Both the distributor and cam gears look ok.
I’ve turned the crank by hand and the engine seems to turn normally, with no binding or strange noises.
I drained the oil a did not find any metal shards (ran a magnet through the oil) or anything strange.
So, I’m seeking some advice from you fine folks.
Any thoughts on what could cause this?
Has anyone ever experienced such a thing?
What else should I check?
By the way, this is a Blueprint 306 Bronco Edition crate engine, that I think came with a Procomp distributor.
I’ve been running this engine for around 7 years.
Thanks!
Thanks!
