5.8 Lightning lower intake casting number?
67 Halfcab
I think I may have located a 5.8 Lightning lower intake, but want to verify before I pull the trigger. Next to the distributor area, the casting reads:
RF-F9TE
9K461
EA
Can anyone verify this actually is a 5.8 Lighting lower intake?
Thanks!
Are you sure about the F9 part of the number? That should be 1999 engineering date.
Have any pictures?
67 Halfcab
67 Halfcab
Here are some pics
At one time I knew all the fuel rails and could tell just from that. I suspect that you are looking at a '99 Explorer intake. If you can measure between the bolt holes, about 9" is a 302 and about 11" is a 351. I suspect that is the common Explorer lower.
Although I am slightly baffeled. By '99 I thought they deleted the internal EGR passage, quit drilling out the intake runner for the ACT and just used the ACT in the MAF, and gone to a non-return style fuel rail. All the clues point to an engine before the engineering date in the casting.
thegreatjustino
Red Head Grease Monkey
Stockton, CA
The search continues...…...;D
Your pictures are of a 351 intake. The clearance area for the distributor is a dead giveaway.
Two 351 lowers on the right in my photo below. 5.0 explorer lower on the left. Yours is clearly a 351.
rguest3
The 351W GT-40 Lower intake was only installed on 2 vehicles from Ford, that I know of.
95 Mustang Cobra R and the 93-95 Ford Lightning. The F9 casting is puzzling? I'm not sure if Ford made an Over-The-Counter aftermarket version or not?
There is also a Cast Iron Version that were installed in Boats.
I'm curious now, I'll have to check what date code is on mine???
I wonder if this was a warranty part. I am clearing a few old cobwebs off the gray matter but wasn't there an issue with a tab breaking off? Most people just get it welded back on and it is fine. Since dealers won't do that kind of work for a warranty repair maybe this is a slightly re-engineered part to fix that issue?
Timmy390
Conway, AR
Only number I can find on my marine cast iron version
Tim
