5 speed or aod?
ochretoe
Millington
I am thinking of ditching the 3 on the tree and putting in a 5 speed or an aod. My Bronco is a daily driver with lots of hunting trips with some interstate miles,and some pretty rough hunting trails. No rock crawling. It has 4.10 gearing so right now 55 mph is about max on the interstate. I am building another 200 I6 to replace the tired one I have in it now. I would like to have the new tranny ready and put it all in next summer. I am not going to go V8 so are there still adapters available? What would you all recomend? Thanks
Steve
74BroncoCO
Do you like to shift? Get a 5spd, if you don't get the Auto. I'm a handshacker guy, so even if I had the choice, I would have went manual. Hunting in the mountians probably means up and down hills and using the engine to hold you back is nice, plus you eliminate the chance of overheating the tranny if you get in that mud hole.
J.D.
You should really check out www.fordsix.com
They have information regarding putting an AOD behind a straight 6. Something the factory never did. That alone may limit your choices.
For a 5 speed, the adaptor to stick an NV3550 behind a smallblock should work the same on a straight 6. More then likely you will be the first gunnie pig for that experiment.
I would recomend a V8 conversion, but if you want to keep a 6 in it, go for it. To each there own.
Come to think of it, earlier this year at the Arizona Classic Bronco Stampede there was a bronco with an injected straight 6 with a 4R70W controlled by a Baumanator. Never met up with the owner. Apparently it did well. I think it was a 250" motor.
Hazegray
I have the AOD (installed by PO), but would have preferred the 5-speed for any up/downhill assaults. Remember if you stall the motor, the AOD goes into free spool mode...not fun at all.:eek:
