6 cyl to v8 radiator swap
Darryl M
Angie
My old radiator bolted on each side with two screws. Changing to a v8 setup, do I have to weld in radiator mounts or what? TIA
thegreatjustino
Red Head Grease Monkey
Stockton, CA
You need the four mounts that weld to the core support. The six cylinder radiator has bolt holes to mount it. The V8 radiator has no such holes.
Speedrdr
Legend in my own mind
Paris, MS
I guess I was lucky the ‘72 that went from I-6 to V-8. I left the 6 cylinder radiator in place and never had any issues with overheating. I guess ignorance is bliss. Lol
Randy
thegreatjustino
Stockton, CA
Randy
Radiator hoses are completely different. How's you manage to pull that off with a V8 engine and 6-cyl radiator?
cps.986
I am also looking for the location to weld the brackets to the core support. Did you end up finding a source?
Someone can supply you with the measurements for the original, but the best bet would be to match whatever Radiator you choose to install. Line up the mounts with their intended bosses on the top and bottom of rad and mark the core support accordingly.
Doing it this way eliminates any problems with modern parts not matching the originals.
Using the original locations has not been much of a problem with stock replacement radiators, but once you go into larger, aluminum, or total custom radiators all bets are off.
armynavy17
Not to mention, as you say all the time, "YOUR bronco WILL probably vary". When in doubt, ditch the tape measure and just do a mock up...
Speedrdr
Paris, MS
The guy that built the engine and did the swap for me was a great builder of drag racers and did some kind of hard lines to adapt the hoses to the tank. It’s been 20 years since I’ve had that one and am kind of working off of memory. I never thought to take photos of the build.
Randy
