6 cylinder Duraspark?
casadejohnson
Bronco Alchemist
Did ford make a dura spark or something similar for a 6 cylinder? I want to get rid of my points in my 66. If so, what vehicles might have it? Should I just by the Protronix Ignitor setup and be done with it?
casadejohnson
casadejohnson
Bronco Alchemist
82 fairmont
That was quick, how did he know that? Then I looked at the list of vehicles you own. Ah Ha says I.
Thanks for the info. I'll try to find one at the junkyard. Any other good donors?
Itsa67
Check out fordsix.com there is a tech article that has lots of good info for you on this modification and many others.
Tony
TOFIC
Bronco Wrencher and Fixer
Redcliff Alberta
any of the ford pickups of the mid to late 80's with the 6 will have the duraspark option. Most are the 300 motor so watch carefully when you do the hunting.
Dont forget to get the coil with it!!
TOFIC
