6 cylinder radiator
twodogs
I recently bought a 6 cylinder radiator and hose kit from Tom's Bronco Parts.
I have a '74 with a 200 inline 6. When I have the radiator mounted with the hose attached, there's no way for the lower hose to reach the water pump outlet. Their kit included a Gates 20706 lower hose. Is anyone using the TBP radiator, and if so, what are you using for a lower hose? Thanks.
Edit: Here's a pic showing how the lower port of the radiator is lower than the stock original, which makes the hook-up nearly impossible. (Cutting the hose to clear the frame doesn't help either....I've already done that).
B RON CO
Statesville, NC
Hi, I can't find a ready made lower hose to fit my Bronco "6". I use a universal flex hose. The upper hose was in stock at Car Quest last time I needed it.
Good luck
T
twodogs
Good luck
Thanks much. I was guessing that would be the case. I searched through all of the hose inventory of three local parts stores, to no avail. It's frustrating that TBP sells the radiator and the lower hose, with the impression that the two will marry just fine. It won't happen.
spap
If the truck is needed or a daily driver, you could probably cut the down leg in that hose and put in a piece of tubing with clamps. Just make sure the tubing has a roll bead or a little welded bead around the circumference of the tube
Is the earlier hose different from your 200? Radiator the same and just the different hose maybe?
okie4570
NW OK
That's the same Gates number listed everywhere for the lower. I noticed the continental brand is preformed like the Gates but says "cut to fit", all three brands on Rockauto are 20"-20.2" long. I know I've replaced them on my two 66 170 and didn't have issues, I'll try to find what I ordered.
T
twodogs
Aside from using flex hose, I'm beginning to think that will be my only option. Even with flex hose, I haven't found one that is 1 1/2" on one end, and 1 1/4" on the other.
T
twodogs
The lower port on the new radiator is lower (~2") than an OEM radiator for a six cylinder. However, the hoses aren't any different, so you can't connect them without causing the hose to collapse. I was going to just drill new holes on the mounting flanges of the radiator to raise it up, but you can't do that without hitting the hood.
T
twodogs
Did you call TBP and tell them what was going on?
Oh yeah. Their response was to drill the radiator flanges to mount it higher (can't due to hood clearance issues). Regarding the hose, they only said that "it should work."
T
twodogs
The hoses will work great on an OEM radiator. The issue seems to be the aftermarket radiator that's sold today. As I mentioned in another post, the lower port for the radiator is lower than an OEM, and therefore the stock hoses won't reach. I'd love to be proven wrong, but I can't find a hose that will reach...and not kink/collapse.
Somewhat along these lines. I had to order a used part from another vendor. I mentioned that I was looking for a radiator and hose combo for a six cylinder. He said that he decided to not even sell them due to fitment issues, with the lack of a suitable hose being the biggest problem.
okie4570
NW OK
Dang, I see. And that's disappointing for something that should be pretty simple to take care of during manufacturing a replacement part.
thegreatjustino
Red Head Grease Monkey
Stockton, CA
Where does the lower port on the radiator fall in comparison to the front cross member?
Any chance you could cut the hose where the white sticker is, attach the hose to the radiator going under the cross member then use a piece of tube to lengthen where you cut it at the sticker?
If you still have the original 6-cyl radiator, take it to an old school radiator shop and have it recored.
66CTBronco
New england
I just had mine recorded with an oem (up in their attic) bucket header core. New hose fit just a little stretch but it fit ok. I wanted to keep the FoMoCo on the top tank and knew nothing about figment issues with new radiators!
C
T
twodogs
I'm pretty sure I can concoct something that will either go under the cross member, or one that stays on the top of it. Both will involve cutting the hose that they say "should fit." I'd like to avoid creating a Rube Goldberg contraption but it looks like I'm headed that way. Sure would have loved to know about fitment issues prior to spending the money on one, not to mention shipping costs :p
I would love to put an OEM radiator in it but I don't have one. The original owner swapped it out for a Mustang radiator at some point. It "works" but the way it's mounted is pretty pathetic.
T
twodogs
C
Guard that one!
T
twodogs
PSA......Happy to report back that I found a molded hose that will work if you buy the TBP six cylinder radiator. The Dayco 70308 lower hose is the one you want to get, and TBP does not sell that hose, as of this writing. Do not try to use the interchange to see what part fits, as the new aftermarket radiator lower outlet is lower than the OEM radiator. Here's a pic of the Dayco hose, as well as the thing installed on my '74 200 cid inline six.
