ctowery
Here we go again.. I have searched and have seen most of the 609 buildup threads but not specifically for my situation so I am asking...
I want a stock width 609 and from what I can see fitting EB wedges is not really possible due to the 1 ton ends and I am not positive their is any reason to use them anyways. Has anyone used Cage brackets with a 3 or 4 link? Is there enough room between the center section and the Axel end for the 1.5" bracket? Will there be enough room for the EB bottom coil base to fit correctly..not lean in?
I plan on using my Coby arms without the U section, just mount up the tie rod's to the Cage bracket holes...do you foresee any problem doing this? If the Cage brackets don't work their are many similar brackets out their to choice from.
I do not want a full width frt and run Hummer wheels, I want to keep what I have.
Any and all sugestions are welcome!
Thanks, Cary
Thanks, Cary
