66 Bronco project
okie4570
NW OK
Mine does not have the original valve cover like yours does, I'd like to find one though. If anyone has one send me a pM thanks
Jeff
That's not an original cover if you're referring to the Powered by Ford script. It still a gold top coil in place on it though :)
1strodeo
Squirrel Watcher
Wisconsin
It says Power By Ford, which I thought was only on the older ones...EB's didn't have that?
chuckyb
Sorry to hear of your loss. Welcome to the best source of knowledge and good luck with your project!
crab
The body sure looks good in the pics. Hard to tell on my iPhone but looks like an older re-paint. How do he floor pans look? Peek under the driver and passenger floors where they bend up. If they are not rotted there, that's a good sign. Not the end of the world if they are. The door pillars are probably your main concern. Can't wait to see it cleaned up!
bmbm
Engine pic
I think all of the parts are there. The carb is in the back of the vehicle and lots of parts around. I will most likely pull the engine and rebuild it myself. Although I would love to re-do it with mods I think I will have a hard time not keeping it original since it looks like everything but the wheels are original.
Looks good under the hood.
bmbm
Engine pic
Engine pic
You can get a cam and other performance mods are available that will look stock. Pertronix ignition is one.
Speedrdr
Not so wise OLD owl
Paris, MS
Engine pic
Amazing how ‘rust-less’ the engine bay appears. Must have spent mos of its life in a semi dry environment. Looks good.
Randy
armypilot_uh60
armypilot_uh60
I looked at Pertronix but it does not seem that have one for the 170 engine. I sent them an e-mail asking about it. Thanks
armypilot_uh60
armypilot_uh60
Here are some photos. I had the radiator checked and it is good, fuel tank is good but the sending unit is bad. New carb will be here tomorrow although I did take apart the old one and clean it. After further inspection I think it has a new engine in it, or rebuilt. Reason I say that is it turned over when I put a wrench on the crankshaft without any effort whatsoever, the top of the Pistons are silver and look clean the spark plugs, although had some rust on the threads from sitting or brand new and has never been ran. The engine blue paint looks to be pretty good shape, and there is blue overspray on the oil filter. The oil is clear, so I am thinking my father-in-law put in a rebuilt engine or rebuild that engine and just never finished it. People in 1966 must've been smaller than today because it is pretty tight up there behind the steering wheel. We're gonna have to do something as far as dates go because my son is 6 foot five and 6 foot one with kind of a stomach and it's just not gonna work. Our first goal is to just try and get it started before going to far into it. I am going to replace the fuel lines, carb, plugs, oil and filter, smack a new battery in it and see what happens. By the way all the dust on it is from being in my shop sitting for quite a few years gathering dirt.
gnpenning
Bronco Slave
Not sure where you are getting the carb from, the 66 was pretty much a 1 year carb that you don't want to turn in for a core.
66 carbs have 3 check balls. I only see one in your picture, did I miss the others? Really easy to lose one if you didn't know. You will never get it to run properly with less. Don't panic if you lost a ball. Even 2100 series carbs check balls will work. I believe it's Michaels Carburetor that has parts and a good video. Even replacement bowl vent rods. It's the plastic looking rod on the top of the carb.
You can use a 4 prong module from a GM hei distributor with a heat sink and proper grease for a ignition upgrade. The points will be the trigger and last much much much longer. Wiring directions are on this site. If you choose to go that way and can't find it let me know, I can try to find it for you.
Manual steering gear vehicles used a larger wheel for leverage to turn. I will say my old 66 turned easily when stopped.
Should be a fun project and even funnier to drive.
bmbm
That may have the load o matic carb and distributor designed to work together. If these are both in good condition they work ok but was definitely not one of Fords better ideas. You could change to DSII but it won't look stock under the hood so Pertronix or similar will work, Moving away from points is good.
armypilot_uh60
armypilot_uh60
I bought a new carb from Amazon know that I would need to take it apart and check it out. However upon first look the linkage is backwards. Maybe I have to reverse it I am not sure or maybe it is just not compatible. Thoughts?
gnpenning
Bronco Slave
The Chinese are really good at duplicating American items, sort of. Depending on how well the specs are written and if they have a inhouse QC person will depend on the outcome. Clearly that carb missed the mark. If they have the linkage wrong who knows what else?? This will be your choice on how to proceed. For me, unless there is something majorly wrong with the old carb i would put a $30 kit and new float in it. You have already had it a part. Overall it is a pretty simple carb. In the future there is no need to take everything little thing off that doesn't have a passage way or gasket. Example, the mounting for the air cleaner.
Let us know what you decide and if you need any help.
I see you started another thread on the carb. Generally it's best to use the original thread which makes it much easier to track conversations and progress. Your threads, so your choice.
armypilot_uh60
armypilot_uh60
Just discovered something which really confuses me now. I just discovered that the carburetor I have for this vehicle doesn't even fit in the holes don't lineup it's too small. I inherited this bronco after my father-in-law died, and it's been sitting in my garage for quite a few years. I am in the garage somebody brought it in to have it repaired and they never came back and got it. This was in 1995. I just assume the carburetor in the box in the back of the vehicle was the one that went on the engine but evidently it's not now I've got to try to find out what is going on because the one that was in the box is an Autolite 1100 type carburetor. Another strange thing is the bolt holes for the carburetor are angled. Most of the pictures I've seen online of other peoples engines the bolt holes are not angled. Might have to make my way to the Ford dealer to find out what actually came on this vehicle.
bmbm
Many knowledgeable people on fordsix.com, a good forum for the 144-250 owner. If you check the block and head casting codes you could tell if a later 200 was swapped in which happens often. My 66 Bronco block was original but had a later head. The later head was changed as far as the carb mounting but I don't recall the details. fordsix.com tech forum here: https://fordsix.com/ci/Tech.html
