Ok so all my measurements are longer than that. My rear leaf springs have 6 springs. 3 have the band around them. The total width of the springs are 2 inches at the axle where they attach with u bolts. I would send pics but can’t just attach them like an email.Not sure if we've ever posted a chart showing the arch, whether installed or loose, but we have a measurement you can make as long as the vehicle is still on the ground and at full weight.
Measure the distance between the top of the axle tube and the bottom of the frame rail. The rear is approx. 6" stock (front is 7" if you're going to check that too) so anything more than a half-inch above or below that is your lift or sag.
If you do not have any lift (there would be no block under the spring from the factory on Early Broncos) then anything below 6" is the amount of sag.
I mention half an inch, but really it should be within about a quarter inch I would think. It's just that there are variations even from the factory.
A roadster vs a half cab might sit differently, but a roadster vs a full hard top and rear tire carrier with larger tire and a roll cage and other additions certainly would.
But it gets you close.
Sent you an email with pics.Right, to upload them directly to this discussion, you need to become a contributor for $12 a year.
However, you can upload them to your “garage“ or “gallery“ functions, and we can still view them if we navigate to those locations.
You can also send them to me at my paulb@wildhorses4x4.Com work email address and I can post them up here for you.
6 total 5 regular and 1 overload.Does your count of six leaves include the thick lower leaf that is usually slightly separated at the end? The bottom leaf is an “overload” so to speak.
Factory leaf springs were available in five or six leaf packs, depending upon which suspension option you got.
The heavy duty had five leaves plus an overload, and the light duty had four leaves plus an overload.
Usually if the main pack is sagging it will touch the bottom overload leaf. Makes the ride real stiff, but also indicates a bit of sag.
Sounds good. Mine aren’t bottoming on overload spring. Haven’t had a bronco before but have a 60 model f-100. Bronco just seems really stiffThanks. I was going to message you earlier, but didn’t get the chance. I got a notification that an email had failed, so maybe our system is giving us a little trouble with pictures.
I’ll see if I can get that dealt with, and in the meantime, when I get back to my computer, I will private message you my Email directly, so you can just send them straight to me without going through our server/system.
I have 285/70 R17 Cooper discovery and they run at 28-29lbsThat's common, especially with the old leaves. Leaf packs often "take a set" where they tend to stay where they have sat for the last 60 years or so almost.
In some cases it's just stiction, while in other cases the tips of the leaves have each actually worn a groove into the leaf above them. This makes the initial movement difficult until they break free, so to speak. Making the ride particularly harsh.
I found this on my '71 and when I wanted a little cheap lift I used add-a-leaves even though I knew (incorrectly as it turns out) that they would make the ride even stiffer.
The result was that, moving each leaf out of it's pocket slightly actually improved the ride! An added leaf must by design make the spring "stiffer" but what went away was the initial harshness of the ride around town. Bonus!
But two other things greatly effect the ride. Along with springs, the shocks and especially the tires have a great effect on perceived stiffness and ride harshness.
So don't automatically spend a bundle on springs and use old shocks and old tires.
Speaking of which... What type, brand and size tire, and what air pressure are you running?
So my next question would it be worth replacing them since I am changing out shocks and if so are those a normal set up or is the add a leaf differentWell, “good“ is a relative term with near 60 year old springs.
They’re still holding the vehicle up, they are all in one piece, and they’re not gonna leave you stranded. However, they are going to ride like crap as all old truck springs did and do, and you may need to replace the bushings.
However, they are perfectly usable in their current condition.
