Slackkinhard
Newbie
- Sep 21, 2021
- 45
trying to post a pic, but evidently I can't handle it
Actually more a pita than I thought
I need some new shocks, so I needed to measure some things with the springs installed.
Now that I've done that, I'm considering replacing the springs. Started looking at the Duff and TBP sites and looks like for the money, I'd be a fool not too. Do I need any other measurements to choose appropriate springs? Is there a way for me to know if I have 2.5 or 3.5" lift?
I installed the springs, put stands under the axle, then measured the 'static' distance between shock mounts. Not exactly sure why they need that number?
Seems the shortest and longest articulated lengths are more important?
I've got dual shocks, the aft shock up front is 20" center to center on the mounts. The fwd shock mounts are 20.5" on side and 21" on the other. A little screwy, but all the mounts look straight and the original install looks proper.
I measured from top of axle to bottom of the frame and I get 8.5" on both sides. Maybe my springs sagged or something, but it didn't look any different to me.
After measuring the rear, some memories are returning. I've got 7.5" in the rear between the axle and the frame. It seems I've gotta 1.5" suspension lift, with a 1.5" body lift obtained by cutting 3" blocks in half.
I've always run 32" tires without any clearance issues and it handled big hits reasonably well...doesn't look like I ever bent/broke anything.
Maybe I should just order shocks and be done with it? I don't want to get into lots of combos to get a small gain. What happens if I order those springs for a 2.5" lift? Seems my whole geometry changes?
Â…Â…. Started as a rewire...
great info. I'm doing it. Ordering the WH spring and 4 shocks.
Thanks Paul, really appreciate it. Do you know if those seat heater elements are a good idea? My lady is sort of demanding them. I'd like to accommodate, but don't want a problem. I've got the original seats, so I need to rebuild them...or maybe there is another solution. I've looked at all kinds of used seats, but really not excited to figure out ergos/fitment/install. I think I'll be happy with the lowbacks...hard to say if my back will need more.
