On my build, I used the Ford coyote control pack. If you also use the starting circuit from the Ford control pack, the neutral safety is built in. The computer knows the gear that the trans is in and prevents starting when in gear.
I can't speak for other control packs though.
I am using the Ford control pack so I should be fine. Was getting conflicting info saying I needed a NSS. I see the starter lead cable (labeled N) on the control pack that goes to the starter.
Additionally, did you remove any leads from the control pack?
Thank you
Yeah, I didn't use the AC Clutch and AC pressure switch wires, I didn't use the Clutch Top and Clutch Bottom wires, I didn't use the wires for a supercharger intercooler pump. There were also 2 leads in there (+ and -) for the HS CAN bus that I wasn't going to use either. I just access the CAN through the OBD2 connector.
It looks intimidating at first, but it's really pretty easy. The amount of wires that you'll have to actually connect to is pretty minimal. Everything else just plugs in.
This has been super helpful. Last question. Did you omit the wires that you didn't use from the control pack? Thank you
Where are you guys installing the power distribution box?
What Gen coyote were you running? I heard that's only built-in on the Gen 1's but could be have been told wrong.On my build, I used the Ford coyote control pack. If you also use the starting circuit from the Ford control pack, the neutral safety is built in. The computer knows the gear that the trans is in and prevents starting when in gear.
My Coyote is a Gen II and I use the control pack to start it. The Neutral safety switch does work with the 6R80 and Gen II.
It reads it internal to the transmission. No additional switch is needed. The control pack has all the wiring in it to read it from the trans.
@tripleJs15
My experience is the same at rcmbronc's.
Gen 2 coyote, 6R80 trans, Ford control pack.
Neutral safety switch is integral to the transmission, and as long as you're using the control pack for your starting circuit, it works.
Reverse lights however are a different story.
I ended up fabbing a bracket that bolts to the drivers side of the trans, to hold a roller tipped switch, that interfaces with a little cam lobe that I added to the shift selector rod.
A bit of a P.I.T.A., but I got it working. Maybe there's an easier way. The transmission itself would definitely be sending the reverse light signal over the CAN bus, but I did not know how to interface with that so I went old school and added a mechanical switch.
