71 Cali Bronco Build
71 CA Bronco
71 CA Bronco
Looks great! That color could be my lubr’s twin[/QUOTE
I just looked at yours. Very nice work there. That does look like a twin. If I would have gone uncut it would look crazy similar. Color is Toyota Calvary Blue. I went Cement gray for the Line-X under coating.
71 CA Bronco
71 CA Bronco
More tub pictures
71 CA Bronco
71 CA Bronco
71 CA Bronco
71 CA Bronco
More of the same.
71 CA Bronco
71 CA Bronco
Atlas cable shifters are installed.
71 CA Bronco
71 CA Bronco
Explorer throttle mod. to accept the stock cable. It worked well except I should have centered the hole a bit better. Had to file down the cowl opening a little to get the cable connected. The hole should have been cut about 1/2" higher in the throttle assembly. It still worked great. Other end is JSmall's (Jaromy's) bracket. Jaromy's bracket fit perfectly.
71 CA Bronco
71 CA Bronco
Hydro-boost install and bleeding brakes.
71 CA Bronco
71 CA Bronco
Ron Davis Radiator installed. Lower hose was a major pain. Had to go to the auto parts store a couple of times and search the back shelf for one that would work. Its really tight next to the 4x4X2 steering box.
71 CA Bronco
71 CA Bronco
Making gas filler gasket and installing.
71 CA Bronco
71 CA Bronco
Making bracket and installing EFIguys relays
71 CA Bronco
71 CA Bronco
Vintage Air install. Needed some butter. Was tight fitting everything in even with raised cowl.
ntsqd
heratic car camper
Upper SoKA
Dang Rob! You're moving on this. It'll be done before I can get over there. Was hoping that work would shut down, but we're an "essential business" due to some of our contracts.
FWIW I've used Dave's Mobile A/C for A/C work in the past and been happy with his work.
71 CA Bronco
71 CA Bronco
Yep, making a bunch of progress due to Coronavirus. Not much money though. Oil and Gas is considered critical infrastructure but NO ONE is doing anything.
71 CA Bronco
71 CA Bronco
My intake design. Found a squared off box from a 2002 Explorer and cut the bottom and created a new flat bottom with materials from American Plastics.
