71 Cali Bronco Build
71 CA Bronco
71 CA Bronco
Thanks guys. I can use the encouragement. Its easy to get overwhelmed with one of these projects. I believe I'm finally over the hump though. Once we get paint on her then the real fun begins.
phred
Earth
Nice work. Wanna come do some panels on my 66 f100.
sprdv1
REBEL
Very easy to do for sure.. I recently am gonna start writing shit down, to remember everything that needs to be done, or mods I want to make
Keep plugging away
71 CA Bronco
71 CA Bronco
Progress made on front clip.
71 CA Bronco
71 CA Bronco
Sand and Prime
More sand prime...
71 CA Bronco
71 CA Bronco
Tailgate
Repaired tailgate gap.
71 CA Bronco
71 CA Bronco
Fold Down Dash
Just sent the Bronco to Line X to coat the bottom. After that to paint shop. Been a long hall. Anyway catching up with progress.
I was thinking about what a pain the painless harness will be to wire to the dash accessories so wanted to make a fold down dash. I had a ton of dash parts to start with.
71 CA Bronco
71 CA Bronco
Fold Down Dash
I obtained a few pieces of flat bar and later a couple of cheap heim joints. The ones without the nylon because I plan to weld on them.
71 CA Bronco
71 CA Bronco
Fold Down Dash
Next I used my Okie brake aka vice to bend my flat bar. Then cut the ends to match the heim.
71 CA Bronco
71 CA Bronco
Fold Down Dash
Heims cut.
71 CA Bronco
71 CA Bronco
Fold Down Dash
Welded out Heims.
71 CA Bronco
71 CA Bronco
Fold Down Dash
Brackets completed.
71 CA Bronco
71 CA Bronco
Fold Down Dash
Test fitting brackets. I just added a nut to the other side of heim and the spacing is about right. These pictures where taken before finishing the brackets.
