Trevor VanLandingham
- Nov 5, 2024
- 38
City:
Gresham
Price: $ 37K23K
Price: $ 37K23K
Selling 71 Bronco. Was restoring it to be my daily driver in my retired years. Was a rock crawler before and is at a stage where it can go either way. The Bronco 302 has a F250 power ram assisted power steering/power brake system from Wild Horse. Warn locking hubs. I have purchased all parts need for 6R80 transmission conversion. (Minus 2014 F150 gear shift assembly about $150 junk yard) Dana 20 adapter, trans adapter, Crossmember and The Quick 6 Computer to run auto transmission + the Transmission cooler adapter fittings. The transmission is great for daily or rock climber Broncos. I have both OEM coil/leaf springs installed and a 5" Wild Horse Lift kit. Also have installed new coil spring cups. New rear brake pads. The body has a 2" lift needed for the 6R80 Transmission. Replaced Both floor panels. 18 piece felt kit for doors. A Vintage air kit Cooling/heat/defrost. I have 2 dash boards one from a Ranger Bronco and the original which is a P.O.S. The diffs are the 44's. New tinted windshield and frame hinge with extra hinge. With many more small items new and OEM with a few duplicates. I have done hours of metal work on the body. 2/3 of the underside is coated with Raptor Lining along with part of the engine bay and all the wheel wells. They were cleaned sanded and etched with marantic acid. There are no seats. The after market seats that were in the Bronco were worn molding and gross lol. I will send along primer sundries (sandpaper, bondo. ect). The Bronco will need to be trailered. The motor is fine runs strong headers dual exhaust 302. I also have the "painless wiring harness some new taillights and 2 dashboard clusters and, have save most of what you need from the old harness.
!!! PLEASE CALL WITH ANY QUESTIONS !!!!
What needs to be finished is the following
Painless wiring harness install
Trans install
drive shafts
doors installed/ windows and felt install on doors
seals for all doors/gates
bleed brakes/check all fluids
Top mounted/just clamped on now for working on it
Paint job
Clean Title in hand.
TREVOR 5034073376 please text before you call I don't answer #'s I don't recognize.
Thank You.
Trans install
drive shafts
Paint job
Thank You.
