Hey everyone,
I'm having an issue with my '72 Bronco, and I'm hoping to get some troubleshooting help. Here’s the situation:
Problem:
Could I have messed up some sort of mechanical linkage?
Problem:
- Engine bogs down under acceleration and won’t get above 30 mph.
- Idles and revs fine in park.
- Has run great for years but sat for a while and wouldn’t start due to no fuel delivery.
- Found the needle seat was stuck, replaced it after removing the fuel bowl, and got it running.
- Now experiencing bogging under load and dieseling when shutting off (less urgent for now).
- Engine: 347 Stroker
- Carb: Holley 770 Offroad Avenger
- Timing: ~12 degrees (seemed fine before)
- Replaced fuel filter (but looked solid)
- Seafoam fuel additive
- Fuel pressure around 6 psi at carb
- Acceleration pump appears to be working as it should (solid squirt)
- Tuned idle mixture screws with a vacuum gauge. Pulls 17ish vacuum; idles well. I feel like I am doing this right but no expert.
- Float levels look good
- Checked for vacuum leaks; none found, replaced all caps to ports
