My engine bogs down really bad
landacre
Spring Branch, TX
I have a 170 in my bronco that has been rebuilt and has always ran good. I ran it with no water and blew a head gasket a while back and have not driven it very hard since then. I took it out for a drive yesterday and i could only get the truck to go about 35 - 40 tops. It seems like it is bogging down really bad. Cracked head? Carb problems? When it is in neutral it runs fine even at high RPMs. It did backfire through the carb while i was trying to drive it yesterday. Any suggestions?
broncnaz
Sounds like a timing issue you may want to check it after that I would check the carb make sure the choke is opening correctly and check the float level worst case you have some dirt in the carb clogging up some passages.
