73 bronco automatic(rebuilt c4)will only start in gear
Magnusvon
My 73 Bronco with rebuilt C4 transmission began not starting in Park. After moving the shifter back and forth a couple of time it would start. Now it only starts in Reverse or Drive. Not in park or neutral.
Where is the issue?
f2502011
Where is the issue?
Most likely the neutral safety switch.
I bet the reverse lights also come on in neutral.
Neutral safety switch out of adjustment. Was probably in reverse instead of park with it was installed/adjusted. Didn't make that last detent into park.
ba123
CA
^^^^^ What they all said ^^^^^^
You can jump it to test if you want or have any issues/waiting for parts, just connect the wires together.
