- Mar 2, 2004
- 561
engine fire took out my harness on my December 1973 Bronco.
everything on the Duraspark side and the regulator side is ok but the center wires going to the temp & oil sending unit are fried and the wires going to the electronic ignition distributor are fried.
I know they make aftermarket pig tail for the sending units but I need whatever pigtail goes from the firewall to the to distributor? The wires under the dash are all fine and even sticking out of the firewall into engine just above the driver side valve cover are ok but just after that grommet it turns into a melted blob and I cant even tell what goes there?
My Bronco is a 12/73 year model, I have heard that the Durasparks differ? my Durspark wires are 7 instead of 6 and go Red/Orng/Wht/Purp/LiteBlue/Blk/Green.
If anybody has the original pig tails that I need or maybe know of somebody that can make some original style that would be cool? Or maybe I need a larger portion of the harness??
A pic of a late 73 or 74 Bronco engine harness in that area would be helpful too?
