The flywheel behind the old 302 has several teeth chipped and partially broken off. I have a 164 tooth flywheel out of a 68 cougar, any reason I can't use it. 68 cougar had a 10.5 inch clutch and the new bronco clutch is 11 inch. The flywheel is the same diameter as the old one so thinking it should work. Any thoughts or should i just spend the $ on a new one?
