Guys,
Any pointers or help would be much appreciated. I'm trying to return my 74 bronco front hubs to stock after someone did a GM disk upgrade. (I can explain why later if it becomes important)
I have ordered and re-ordered used hubs.. and I now have 4 used front hubs and I'm trying to get two that work.
Napa told me the right bearing and Oil seals are the following:
Napa BR37 larger bearing
Napa BR35 smaller bearing
Napa 24917 Napa Oil Seal.
Well - I have 4 front hubs that the parts supplier said came off a 75.
My bronco is a 74. but OK
One of these hubs is different from the others... (this is not a sesame street joke) someone sent me a "set" of hubs that didn't match and then re-sent me another set.
So now I have 4.
Here's the situation:
Hub Candidate #1 -
Napa 24917 Oil seal fits,
BR37 Large Bearing fits
BR35 Bearing just drops in and doesn't seem to fit - loose inside the tube
Hub Candidates #2, #3
Napa 24917 Oil Seal is too big... does not fit
Hub Candidate #4
Napa 24917 oil seal is too big
BR37 and BR35 seem to fit
On the spindles the br37 seems right
The br35 seems a little small.. this would all make sense if hubs #2 and #3 are good and the be35 bearing and oil seal are not right
Any ideas??
I suppose I can go get an Oil Seal of some kind to fit.. but I thought the BR35 bearing was supposed to be correct. and it makes me think I've got something wrong..
My current hypothesis is that.. I can get an oil seal that fits these other hubs someplace.. but why this one doesn't fit concerns me..
and the smaller bearing must be wrong since it seems to sit a little high/tight on the spindle so maybe that's just the wrong bearing and I need one slightly larger.
I don't know!
Here are the bearing sitting on the spindle which I hope is stock and correct for my year.
https://74bronco.shutterfly.com/pictures/95
and here are the 4 hubs i'm trying to make two good ones out of this pile of parts!
https://74bronco.shutterfly.com/pictures/92
Thinking...
Either Napa got the parts right for a 74 bronco dana 44 and the 75 hubs are different/wrong
Or these are the wrong napa parts for the outer bearing and oil seal.
IDK - I've been messing around with it for 2 weeks now.
Very frustrated.
So now I have 4.
Hub Candidate #1 -
Hub Candidate #4
Any ideas??
I don't know!
Thinking...
Very frustrated.
