I listed this toward the end of last year. A deal fell through and then I've held onto it a while. I'm not going to end up building it, so I need to get more serious about finding it a new home...
I purchased it in 05 and it's pretty much sat since then. It's in the same condition as when I purchased it, so I don't have details about miles on the engine swap, etc. What I do know is below.
It's a 74 (built Sept '73 by the data plate). It's got a 351 Windsor backed by an auto trans (assuming the original C4, and it shifts good). No info on the details of the motor, other than it looks like an early 351 to me. No idea what the actual miles on the engine is either. Power steering. Dana 44 front axle with disk brakes (not power). Rear axle looks original, and untouched. Transfer case has twin sticks - rear shifts pretty well, the front is a little sticky. High & low work on both axles. Dual exhaust that sounds good. Truck runs and drives pretty well for as much as it's sat. I drive it a couple miles every couple weeks, and it fires up and goes great. Rear fenders and dash are uncut.
Now for the bad - it's a Missouri truck (originally delivered to St. Louis), so it has the typical MO rust. I've tried to take pictures of everything and post them, but here's the details:
It also looks like someone ran into something with the pass front corner. I'd probably just replace the fender vs trying to fix it.
The front gas tank has developed a leak.
I think that's everything that I can think of right now. It's a solid truck, and a great project. If it wasn't for the rust, this would be an awesome truck. I'm not a body guy, and I'm not intimidated by the rust, so I definitely think it's fixable by the average guy (or I've watched too many automotive shows on TV).
Thanks,
Danny
- Driver's and passenger's front floor is through the inner layer, but not the outer or the cross members. Is through at the seam and can see daylight on both sides.
- Driver's rocker is rusted through on the side, but not bottom. Looks like it may have had a bondo repair at some time???
- Driver's door jam looks good.
- Pass rocker is rusted like the Driver's.
- Pass door jam does have rust through.
- Belt line rusted on both sides. Driver's side isn't too bad, but the pass side is.
- Rear floor has some rust - a 4" x 4" hole in one spot.
- Rusted through above the wheel tubs on both sides in the rear.
- Tailgate is toast.
- Front inner fenders rusted right in front of the firewall on both sides.
- Top has some surface rust around the drip rails, but it looks cosmetic. The top appears to be in really good shape except for the antenna hole that someone put in the middle...
Thanks,
Danny
