74bronk
- Sep 1, 2004
- 358
i have a holley truck avenger carb had it rebuilt. Motor is a 302 by the way. replaced basically all ignition system except the coil. (truck had been sitting a couple of years) it starts up good cold. then after it warms up when you put it in gear the idle drops real low then if you don't put your foot in it it will stall.....i adjusted the idle control yeah i can turn the idle up but in park it idles really high and when you put it in gear it lunges. also in gear while idling the motor vibrates and shakes....not sure what that is about. so i believe there is something im missing on the carb setting any help would be appreciated! if something else please let me know
