Western Okie
Bought this 74 last week and the owner before me installed a np 435 in place of his automatic.Where the shifter on the column was there is alot of slop.The turn signal switch is bad so i thought while i was in there i would try to fix this to where it wasn`t so loose.When i took the snap ring off the upper bearing and slid the upper part of the column off and then the collar with the long tube slid it all the way out.Is there suppose to be another bushing/bearing somewhere in the bottom of this to hold it tight??
Thanks for your help,
Matt
Matt
