Are you referring to the year of the design for a replacement EB spring Jim? Or are you thinking of the later model truck springs?
If the latter, then there is no comparison and they won't work on an EB at all without some serious fabrication of mounting points.
The lower is not even remotely the same design, and the spring rates would not be correct for the lighter EB's anyway.
But if you just meant the newer concepts, or variable rates in general (it's not a new concept) then I say they're way better than the old originals.
Some are still getting good results with linear rate coils too, but if you're not running a heavy truck (big bumpers and winches and engines and such) then a variable rate is a great street-friendly spring.
