76-77 sway bar passenger bracket
stretch
Montgomery, TX
Well this is a problem with a 20year rebuild. I have a 77 which was set up for the front sway bar. I recently sourced a really nice sway bar with all the brackets minus the passenger of coarse. I didn't bother looking at the axle because I know I have that bracket welded on. I should have looked at the axle. It was there, but a removed it ten or so years ago to weld on a track bar riser.
So here is what I'm looking for. Those of you that have this bracket on your axle, could you get a measurement for me. I need the distance from the axle tube to the mating surface on the bracket. I should be able to fab something up using a spring perch, but would like this distance just to be in the ball park.
klcornett
Is this the measurement you are looking for? The camera angle is a bit off. The distance from the axle tube to mating surface is 1 3/8". The mating surface is 5 1/8" long, 1 1/2" wide with holes on 3 1/4" center.
