I got 2 problems!
#1 - Right side came apart just like it should, except for the spindle, will not budge, only used MFH (medium) with some puller tension, will try some heat and BFH next.
#2 - left side inner clutch is froze inside hub, have tried several home grown type pullers, nothing!! Is there a puller for this clutch?? It's pretty tight between the axle and the clutch and maybe a 1/4 behind the clutch!! I'm thinking BFH and a chisel???
All advice appreciated!!%) %)
TIA
TIA
