76 Lower column/shift tube connection question
R3
VA
I removed my shift tube to replace it without removing the steering column. I couldn't put the beast in gear and once the shift collar was removed it was clear that the tab at the top of the shift tube was broken off completely (the lower tube is intact). Now it wont seat properly with the lower bushings (or so it would seem, I cant exactly see inside the column). I can't get the ube all the way in. I tried checking diagrams on JBG but there is not enough detail on those smaller parts. What the deal here? Is something else stopping it? Is there a way to reassemble it without removing the column assembly entirely? BTW I've never had a column apart before (ain't it great)
BlackHorse
You should be able to do this but you will need some help. When you remove the tube the shifting arm will need to be in line with the tube when you put it back in. You will need to line up the shifting arm from the engine compartment side. As long as the shifting arm is in the right place the tube should slide in.
tcjones76
Tyngsboro, Ma
If I remember, there is a spring in the column. When I repaired my shift tube, it was a matter of trial and error (read: pain in the a$$) to get the lower tab into the shift linkage with the spring in place and then getting the upper shift collar retaining bolts in place. <br><br>My shift tube let go just I was leaving the campground after a trip with the Eastern 4 Wheelers last summer. I got home by starting the Bronco in neutral with the ebrake set, shifting into drive by reaching down under the master cylinder, slamming the hood and jumping back into the cab. Thank goodness for drive-thrus!<br>
R
R3
VA
Thanks guys. looks like I'll need a hand with this. Since my e-brake doesn't work i've tried several methods of the "jump in start" too - very scary when you're alone
Hnrys69
Take the column out, its super easy (working on a writeup soon about swaping columns) get it on your work bench then its easier to check whats going on. Then put it in when its working as its supposed too.
