'76 steering linkage
surfer-b
Could I just cut my 77 drag link and put an adjusting sleeve in to center my steering wheel after a 2.5" lift?
Sure, thats what I did. I wanted my steering wheel centered after I installed 2.5" springs, here is a pic after I welded in the adjuster. The biggest prob with the 76/77 set-up, other than its weaker than the T style, is any time you add or subtract weight in the front or back it will change the toe.
surfer-b
Did you just cut the long bar and have it treaded?
No I used an adjuster and threads from an old tie-rod. Connect the threaded ends with the sleave/adjuster and leave a space between the 2 so you will have some adjustment to close it up if needed, take a measurement and remove that amount form the drag link on the 76/77 and weld in place.
