77 302 engine casting number?
SeaVee
Does anyone know where it is on the block? Speaking to an engine builder and he said he needs it to price correctly
TIA
EPB72
Pleasant Hill, CA
Date code for block is on right side above oil pan rail behind starter ,,pull starter and you can't miss it....
? are you rebuilding what you have ,,,or is the builder using there cores ....
I'm understand where the builder is coming from, but a little confused as well.
I understand he wants to know what he will be working with. There are little changes over the years where you need one part over another. The 351 had a fairly major main bearing revision in the 70's (although that doesn't apply here) but there can be little things like that.
But...
Until you take it apart you don't know what you really need. If it is really mint inside a quick hone, rings, bearings, seals, new oil pump and the short block is done. Maybe the crank needs grinding, undersized bearings to go with it. What bearings for an overbore, will it even take an overbore? Does the deck need machining? Some shops will machine the deck if it needs it or not, more billable hours. The point being is they can't tell you what it will cost until they know what is inside. To get inside they will have the casting numbers right in front of them. Both the block and the heads, which may not match the block if it ever had a head job in the past. It was common in the past that a machine shop would keep sets of heads ready to go and you exchanged in your old set. You might get back a slightly different year, but they still work.
So how are they going to price a rebuild for you off the date of the block? Do they just plan on machining everything regardless if it needs it or not? Great way to rack up billable hours and you have to use new parts inside to match the new diminsions. Shoot high, aim for big profits? Or shoot a low estimate with a minimal estimate and give you the bad news once they open it up and it needs more than the original budget accounted for?
A custom built ening based on a stock block, there isn't enough block variation over the years to really affect much. Other than maybe they want to use a roller cam and you don't have a roller cam block. But it is easy enough to just pick worst case and discount if you had the right one.
I sure hope they are not ordering a rebuild kit based on the year of the block and without a tear down inspection.
jamesroney
Fremont, CA
Really hard to see, but pretty easy to take a picture and then read the pic. The picture below is between the starter motor and the pan rail. I think your 77 would be a D4DE block. The casting number moved in 1985.
Rustytruck
in 1973-1974 ERA was a deck height change dropping compression and was a regional thing not a wholesale across the board change.
S
SeaVee
Thanks guys, I’ll pull the starter and take a look. There are some numbers on the exhaust manifold. D5DF-9430. Other manifold is D80F-9431.
I have someone that can rebuild the engine but he’s pretty booked up. I was considering a crate drop in to see if I could get one quicker, plus the warranty is nice if I want to sell it when it’s done. I have a reman Jasper 8.1 in my Suburban and it’s been great
The D5 manifold got the last design change in '75. Completely expect to see that on a '77.
The D8 manifold is interesting. By nature of the engineering date (1978) it is too new for a '77. But it could be factory, or a service replacment. That is the new for '78 manifold got an early production start and spilled over into the '77 still being built. Or the original manifold cracked and the service part was revised to avoid cracking and the revised part was released in '78. Don't really know why there is that '78 date on a '77. But close enough I would not be worried about it. It is installed and functional.
jamesroney
Fremont, CA
Found it : D4DE-8018-BA
No, but it’s probably D4DE-6015-BA
There’s a date code cast right next to the number. In my pic above, mine reads 7F10. The date code will tell you if it’s original. (Or at least it can tell you if it’s not original)
bronco t
San Diego CA
Hmmm... my 6/77 build with a 302 is coded D8VE 6015 A3A 7E27 and the driver side exhaust manifold is D3OE 9431 EA. So, either I have a franken motor, service replacement parts, or Ford was scrounging parts to get these out the door?
jamesroney
Fremont, CA
The D8VE-6015-A3A is special. You are lucky. May 27, 1977 casting date would be good for a June build. Should have the thicker main caps like the 289 HiPo.
