77 Broken Wheel Stud Front
lonesouth
Should I go ahead and replace all of them while I'm servicing the brakes or just the broken one?
Are they a press fit just like the rears?
Pa PITT
Stephenville TEXAS
Time to pack you front wheel bearing ...a job I really hate but after it's done depending on how you use Bronco it's good for one or two years ....Pack all the bearing and look over you brakes and whip on a lug bolt or 5 at about a dollar each 1 or 5 who cares ..You can knock them out with a 2 pound hammer with no problem ..
lonesouth
lonesouth
i got new bearings and seals, store only had 3 studs so i replaced the broken one and the other I pulled for a comparison to new. I did learn that if you don't drive out the original outer race, it becomes really hard to find later and you can't get the retaining nuts to seat fully...:p
