77 Bronco - Build In The Works
R
rguest3
I'll drop in the Coyote today and check clearance and see if there are any issues with the TDK frame.
I almost changed my mind and wanted to go with a 351 Windsor instead.......
rcmbronc
Tomah WI
I almost changed my mind and wanted to go with a 351 Cleveland instead.......
Will be good to know. I last week ordered the TDK frame and had it made wider for the Coyote. Who's motor mounts are you using and how much body lift? Stock frame motor mounts?
R
rguest3
Im using the BC Motor mounts and probably a 2" Body Lift.
The Motor Frame Purches should be stock width. I need to measure because they seem a little wider.
R
rguest3
I think I will put the Coyote back in line for another project. Other 77 maybe.
I installed the Coyote on the TDK frame yesterday. As you can see from previous pictures I have the Tall shock towers installed on the frame. I had to "shim" the Passenger side motor mounts to place the engine a hair higher and to the left to help the passenger side header to clear the shock tower. The Headers still only cleared by about 1/8". At this point the Power Steering pump was next to the Steering Box. It's too tight of a fit. If I had the Stock Height Shock Tower I do not think this would be an issue at all and the Coyote motor would just drop right in.
The BC serpentine system, Motor Mounts and the Angled Oil Filter Housing fit great. My only clearance issue is with the custom taller shock towers.
The TDK frame, is very nice, and should work great with a Coyote install with or without the extra width option.
I will go back to one of my initial options and put the Coyote in the 77 Frame..... Not a bad option.
R
rguest3
Back to getting some progress done on this Bronco. I should really re-start this Build thread because everything has changed.
Original 77 Frame and Original 77 Body from Arizona.
Here is what the Rolling Chassis looks like currently as of today.
Mocked up Duffs Dual Sport 4-Link at 93" Wheel Base. Nothing is welded or adjusted, it's just assembled with the Brackets Clamped in place. I did bolt on the Rear Coil Buckets at recommended height.(Even with the Bottom of the Frame) I did not trust a Clamp to hold these in place. I'll remove the bolt once welded.
Next is Swap out to Front Coil-overs when they arrive, install Drivetrain, Install Body with Roll Cage, get it to as close to full weight as I can, then adjust 4-link and final weld Brackets. Then take it all apart again and Powder Coat Frame. PITA, but I really want to do this one as 100% as I can.
R
rguest3
The 4-Link has been mocked up and welded.
Today we got the Coil-Over Conversion pretty much done.
King Coil-Overs with 300/300 Springs
12" Coil-Over Towers
Lower Dual Flat Mount with Round Pad
I was going to weld the lower mount to the Knuckle on the end of the axle but the mount would have been too wide. As it is now, the Coil-Over is angled out just a hair. The lower Mount / Pad are welded together and bolted on top of the Hellwig Sway Bar Bracket as the Original Coil Retainer would be. I had to use the Pad as a base for the Lower mount because the Sway Bar Bracket mounting prevented all to line up correctly. Seems to line up very well and is very strong too.
It's a little higher in the front as I wanted, (Pad does not help) but I am hoping the Body with Roll Cage, HD bumper and everything else the front will come down more.
R
rguest3
We got the body Installed at the Shop this morning. The Suspension is actually a lot more level than I thought it was going to be, but it is higher than I want. There is a 1" Body Lift installed too.
Now I will see if the suspension will settle 2-3" once everything is installed. I currently have 300/300 springs installed. I'm anticipating going to a lighter Top Spring (200 or 250) in the Coil -Overs to lower the height some. The rear coils will come down easier since they are not as stiff.
285 / 75 / 17s installed on 17x9 Classic Locks.
Here is a picture of the fender flares being set-up. Not aligned yet but I think they will look good.
Making Progress.
R
rguest3
More work completed on the Bronco this morning.
The Rear Axle has been squared up and Plum under the Rear Coil Buckets. The Front Radius Arms are square as well. The Coil Overs are straight up and down now.
With the Axles now where they should be, the Fender Flares are aligned up and ready to cut metal.
The Rear did squat more with most of everything installed as you can see. The Front Suspension did come down about another 1 1/2" but needs to come down another 1" or so. I'll add the winch and see where it is then.
thiswildbronco
Looks great!!!
Where is the roll cage from??
I also plan on a 4 point cage with arms forward to windshield.
R
rguest3
The Roll Cage is my design built right next door to the body Shop. The guy builds Cages for NHRA Cars. Beautiful work. DOM that ties into the Windshield Frame. He works for the county now, too bad he only builds for himself. This Cage is my last one.
thiswildbronco
Looks great. I'd love to see a detail shot of where they meet the windshield frame if you can swing it.
The Krawlers Edge cage is a bit ubiquitous and I don't love their corner joints. This cage of yours has nice lines to it!!!
R
rguest3
You can just see the very front of the bar that goes to the Windshield. Bar is cut at an angle. Then bent plate welded to bar at (Same angle) and flat where it attaches to the top of Windshield at existing holes.
R
rguest3
I am in the process of reconfiguring the original 77 Dash.
These SpeedHut Gauges will go on each side of the steering column.
4 1/2" GPS Speedo with Tach, Turn Signals and High Beam.
4 1/2" Quad Gauge with Fuel Level, Temp, Oil Pressure and Volts.
The SpeedHut Gauges are completely customizable. Sizes, colors, and just about anything including logos.
The Optional Pointer color on these are White for Daylight but Glows Red for Night Driving.
Sorry they are sideways in the picture.
sprdv1
REBEL
Very nice.. Something unique you don't see all the time
Pic fixed
R
rguest3
I am actually very impressed with these gauges. I can't wait to see what they look like with the completed dash.
txtruk15
Highland Village, TX
those are great looking, exactly the colors I would pick
R
rguest3
AX-15 Transmission.
Not going this route.
R
rguest3
Gen-2 Mustang 5.0L Coyote
Not going this route. This motor will go in another vehicle.
