I just posted on the "Chat" side, that I acquired a '77 mid build
In 2007 they installed the James Duff 3" body and 5" Suspension parts. (it is still sitting on stands)
It is presently mocked up with no wheels or tires (don't have any)
The body shop had made custom brackets to correct the bumper heights and the twin shock mount has been welded. Such that lowering the body lift will be undoing more work than I realized.
So If I leave the 3" body, I can go down to a 3.5" lift without too much effort. As it has the trac bars that need at least a 3" Suspension lift to work
So does anyone have or seen a 3" BL and 3.5" SL? Does that seem reasonable?
I hope to not cut the fender, and I also have C4 and 4.88 gears now with truetrac. I was advised to try the 4R70W which at this point seems like a good option.
As far as tires, I don't need really wide tires.
I am thinking a 33" x 10.5 would be the sweet spot
I guess another way of asking is 6.5" LUBR vs cut? What tires will work with a LUBR
Any thoughts on this setup? Thanks guys
