redfishtony
OK I think I got lucky. After cleaning this axle up and getting the numbers off the tube it appears to be a 77 Standard with 3.50 ratio. My existing 9" is also a 3.50 ratio so I should be good to go. It does appear to have bigger u-joints so I assume the axle ends will be different also from the standard D44 short axles. The measurement on the drivers side is almost exactly the same as the D30 I removed (within 1/4") so all I should have to do is move the wedges just a bit. On the passenger side the tube is 4"+- longer so I will shorten this side. It seems removing it from the housing would be better but will I be able to get it back in and straight? If I go the other way I will have to cut the wedges and C off and but the tube should stay straight. Maybe the better way afterall. Sorry for the lengthy post. I have attached some pictures before and will try to post my progress. Wish me luck. ;D
