77 front end rebuild problems
broncofl
Mary Esther
I have just finished gathering all the parts for a front end rebuild, new ball joints, spindles, ujoints for the axles, hubs and rotors, bearings, etc. I have started putting it all together. I have run into a problem which I haven't been able to figure out, maybe someone has seen this before. I have installed the new ball joints, axle u-joints, and the spindle bearings came installed in tom's spindles. The book shows the spindle sliding over the axle (with spacer and rubber gasket, connecting first to the steering knuckle. When I get to 1/4 inch of flush with the spindle, the axle gets real tight, and even turning the knucle from side to side is real difficult. If I tighten it more, its almost impossible to move the knuckle front to back. The book shows the knuckle, spindle, disk brake dusk cover, disk brake support bracket, then hub/rotor assembly in that order. Am I doing something wrong. I checked all the new parts with the old and they are the same. ANY help would be appriciated. Thanks
If Iwe can get this figured out the next step is Tom'sBG heim joint TRO upgrade which is waiting on the current problem
Broncofl
fordtrucks4ever
DFW
Are you sure the inner axles are all the way in? You may not have them completely in the splines. When everything installed correctly, the inner axle will have a lot of travel limited by the snap ring on the outer shaft.
broncofl
broncofl
Mary Esther
Slip axles all the way in prior to putting spindle in. Does anyone have some pics of a 77 front end? either disassembled or together?
mr.n
Never finished the page... but my notes:
http://77cj.littlekeylime.com/Mr.N44.htm
It's a general Dana 44, might not be dead on is close enough for all I've built.
mr.n
I'm not following you... tighten what?
It's common for me to grab the u-joint and pry back and forth. Try pushing the axle in further.
If it's binding something is in the wrong order.
broncofl
broncofl
Mary Esther
Thanks, I read your article prior to pulling everything apart, I like doing the research prior to starting, great article, but it still is confusing with the second diagram I got from scsm76 "http://classicbroncos.com/forums/showthread.php?t=107754
this show a different order for the spindle, dust shield and disk support bracket. The problem is if I install the spindle directly on the knuckle then the dust shield ans support bracket, as Im tightening the 5 nuts, when everything gets to within a 1/4 inch of the knuckle, the axle binds and won't turn, plus the entire knuckle refuses to swing left or right. loosen it back and everything work. Tried leaving the spacer out from between the knucle and spindle, it got closer to being tight but still jammed.
Any help is appreciated!!
broncofl
broncofl
Mary Esther
wrong order???
Thats what I'm thinking, but almost all of the diagrams show the order knuckle, spindle, dust shield, disk support.
Everything jams as I tighten the 5 nuts holding everything together in the order above
Thanks for the help
mr.n
I don't have a Ford diagram handy... and it's been too long since I did a Ford Dana 44 to remember...
Sorry, I'm sure the crew tomorrow will get it.
Apogee
Tangent, OR
...The book shows the knuckle, spindle, disk brake dusk cover, disk brake support bracket, then hub/rotor assembly in that order. Am I doing something wrong. I checked all the new parts with the old and they are the same. ANY help would be appriciated. Thanks
Broncofl
My '77 has the caliper mounting bracket sandwiched between the spindle and the knuckle. Mabye I'm just reading your original post incorrectly, but it sounds like you're stacking them on the outside of the spindle flange...that isn't correct. The caliper mounting bracket is about 3/8" and the dust shield (which I chose to omit) is maybe .040" on top of that. You already know what happens when you don't have them installed. :cool:
Tobin
Gummi Bear
Apogee's got it right, the disc bracket goes between the spindle and knuckle.
Leave the stupid dust shield out, it's just a crud catcher anyway. I tossed mine a long time ago, and have never missed them.
broncofl
broncofl
Mary Esther
Great, Thats the info I needed
Thanks a bunch, figured that would give me the space I need to keep the axle from binding, but with all the diagrams showing the spindle butt up against the knuckle wanted to make sure. Your not having any problem running without the brake shields? What happens when there not installed?
Thanks for everyones reply
Tobin
Apogee
Tangent, OR
In my experience, nothing happens when brake shields are not used. Mostly they just block air flow and fill up with mud and crud when bogging through ruts.
kbldawg
Marshall, AR
Is it advisable, if you choose to omit the dust shield, to keep the same tolerances by cutting the "bolt ring" off the dust shield and installing just that portion?
Does that make sense?
Apogee
Tangent, OR
That totally makes sense, but it's not necessary. You've got enough float in the caliper mount and clearance between it and the rotor that it doesn't matter either way. I double checked everything when I did mine and it worked out fine. The short axle shaft will protrude into your hub by an additional .040", but that doesn't hurt anything either. ;D
