Hey man so if you go to my post number six I think basically the bronco came with a push button start and a HEI rigged up. I was just making sure I was suppose to splice them two wires together because they had a push button so I had to identify the wires and the diagram and makes sure I wired it up right is all but, sorry for the confusion , I spliced 16 and 904 to each other then butt connect to the single Red w g wire on the ignition pigtail in post number 6. So yea the painless kit came with some extra wires as if you never had a duraspark set up. Here are my connections. Set the timing to 10* on the crank rebuilt the carb 2150 2 barrel new “42” plugs and new wires, I drove it for the first time 3 speed on the tree it had no breaks right now but man the motor runs great ! Need more work but atleast turn key
Factory brown and red with blue stripe at starter relay
Factory red with green strip comming out driver side fire wall connected to painless + ignition coil
Factory blue and red w blue stripe going to the ignition module plug n play
Only have two extra wires left and one is for a tach wire yellow and the brown would be the starter solenoid ignition post but I'm not running it , could I use this wire for anything else ?
The purrrdyyyy side needs rear flares
Need to work on battery cables power steering leak breaks , they only have one thick wire running from the alt to the battery I'm guessing this needs a mega fuse they have the factory alt wiring zip tyed up should I get a stock alt or keep the one I have and add a mega fuse ?
Here is the alt one big red wire to the Batt terminal is all they had
Probably made this more difficult wiring isn't my specialty made more since with parts bolts on first and looking at both diagrams
Thanks for the help man
