That's a great observation, and I didn't understand it myself. I couldn't make sense of the Autozone listings...since they reference the Ford Part number...of which I am not familiar.
The Autozone reference nomenclature gives you the prefix, and the suffix. So E8ZFDA is shorthand for E8ZF-12A650-DA which is listed as a manual transmission, California emissions Mustang.
The A9L is labeled as an E9ZF-12A650-A2A
The A3M is labeled as F3ZF-12A650-DB
The 8LD is labeled E8ZF-12A650-D2B
I couldn't make sense of it because some of the computers are $104 to $179, and the cores are $46 to $120. I couldn't cross reference the A9L in their listings.
But the 8LD is an 88 Mass Air 5.0 5 speed, and should work just fine.
There's no reason why an aftermarket ECM should be any better, worse, or different than OEM depending on the source. The Global Tantalum Capacitor problem has been resolved...and should no longer be an issue.
I ended up buying a used A9L that was cut, and chipped...but it worked. I am interested to learn what you find out.
