9” Housing stud question
junebug
So I bought a super 9” housing from WH and purchased new studs for the housing (from speedway motors). I have destroyed 4 studs trying to press them in stripping out the threads. Before installing them I left them in the freezer overnight expecting a tight fit. Just ordered 10 more studs but these things are expensive… I don’t want to mess up any more. Has anyone purchased this housing and found the holes to be too small? Does anyone know a part number for the studs to buy at NAPA? Would really like to get this thing back in over the weekend….
nvrstuk
PNW
Did you call WH about the proper size studs that need to be used or if they've ever had a similar issue?
I have no idea when you posted this when they were still open.
Sorry, I meant to check and respond but got sidetracked and waylaid and shanghaied again.
I did not get an answer in time, so can't say that ours are supposed to be any different in size than the stock originals, but I will find out. Our #8698 Stud Kit (https://www.wildhorses4x4.com/product/Third-Member-Hardware-Set/earlybroncothirdmember) shows up at the bottom of the page in the list of options when viewing the housing, and also on the main "3rd Member" page.
Sorry it does not automatically pop up when ordering (or maybe it does?) to give you the choice.
Good luck. Let you know what I find out.
J
junebug
I called before I bought the studs, they guy I spoke with said the should be regular studs like the factory ones. Unfortunately I didn’t think about buying them when I bought the housing.
Can you get a measurement on the holes by any chance? And on the existing studs that you purchased?
Might be good to make sure what we’re dealing with here.
Whether it’s a known mismatch, or something new.
How did it go this weekend?
The info you got previously was correct. Just confirmed (for my own peace of mind) that they are just standard sized Ford 9" studs. Nothing exotic...
So definitely double check the hole size in your housing. If the press-fit is too tight, you might just ream them out a tiny bit so that the studs you have are not so hard to press in. Maybe there is a rough edge to them that is causing some extra resistance?
Of course you should not be required to do this, but short of finding some crazy new method of pressing them in, it gets you back in business sooner rather than later. Without any more buggered studs, or waiting for a new housing that might have the same hole size that would not fix the issue.
Let us know how it works out.
Sorry about the hassle.
J
junebug
So I checked the stud manufacture’s website and they recommend a 25/64 bit. Which I purchased and used to open the holes up. It did remove a considerable amount of material. After that I found that keeping the studs in the freezer overnight helped to set them in. Currently I’m waiting replacement studs to finish up the install. I also want to verify that the studs are correct as well and that there weren’t any packaging errors by the fastener manufacturer.
Rustytruck
did you try to pull them by the threads? if so try putting the stud in place and slipping a socket over the stud and use a C-Clamp to tighten it all together pushing the stud in from the bottom.
