JSmall
- Feb 18, 2004
- 3,224
The seal requires about .045" of crush give or take, so you do need to suck it down in order for it to seal properly. The "skirt" of the seal around the bearing bulges out into the wall of the bearing counterbore to make a seal...without the crush, no bulge and no seal, hence all of the complaints of leaky SET20 bearings. If you look inside the seal prior to installation, you'll see rubber ridges that are about .06" tall that compress against the inner bearing race.
If your housing ends are exceptionally worn, damaged, scarred, etc, then it may never seal without some RTV or other measures.
I tend to run thicker retainer plates with SET20 bearings for less distortion, as even the stamped OE plates tend to wrap around the bearing/seal upon tightening. As for the gap, the assumption is that you have a ~10 gauge (.134") drum brake backing plate and gasket (~.020" FelPro #55036) between the retainer and housing end.
Tobin
Great info Tobin! I have the thick retainer plates from Yukon and the drum backing plate is used so I'm thinking I get the gaskets you mentioned and then suck it down. Will there be two gaskets per side?
