- Nov 3, 2003
- 47,919
Not sure I've ever seen a switch lock like this before OM. But it seems like we should have heard of this more often.
Surprised that something got into it, that all of your spraying and banging hasn't dislodged yet.
What about this though... Remove the nut on the center stud holding the Black w/green accessory wire, and the whole strain-relief part of the wire connector. Pull the wire connector off too, and see if that stud will move in and out at all.
At this point you aren't really worried about buggering the switch anyway, so you can even give that thing a good tug and smack or three.
While you're messing with the stud, fiddle with the key and see if anything loosens up.
Good luck.
Good luck.
