96 Explorer Serpentine setup
74bronc
I have located a smokin deal on a complete 96 Explorer 5.0 serpentine setup including A/C compressor, alternator, p/s pump and remote reservoir, front cover, pulleys, damper, bolts, idler pulley, etc. Has anyone on here done this conversion? I need some specific questions answered. anyone?
One of the bronco houses has it as a kit
I have a friend who has it on his 5.0 in a bronco.
yes it fits, and it works. Best way I know of to get a good clutched fan to fit.
74bronc
74bronc
Thanks lars. After I posted this, I found Brian's page. I also found a pretty nice write-up in the arizona classic broncos newsletter that I found online somewhere.
yes, a few of the bronco houses carry this same kit, but they want $1800 for everything (Extreme Automotive in San Diego). Granted, that is all new stuff but I am getting everything I need (used) for $150. Brian Wickert gets $700 for complete used setups and that is a good deal. Hot damn, I get 3G, remote res. P/S, A/C compressor, huge-A clutch fan, plenty of radiator clearance etc.
PABrian
North central PA
So basically, to use this set-up, you need to get a radiator with reversed inlet/outlet, like the EFI right? Because I wouldn't want to run those extra long hoses that wind around the whole front of the motor. I'd like to use this set-up on my stock 302 with a new radiator, I just need to know which one to use.
Thanks,
Brian
74bronc
74bronc
Thanks,
Brian
Yes, you have to either use a special hose for the bottom hose since the explorer water pump inlet is on the driver's side and the stock EB is on the passenger side. You can either have your inlet and outlet changed at a radiotor shop or use a special bottom hose. I am going to get my radiator switched.
