Stock Engine, first run in couple years, runs great, good throttle response, BUT
has a rattle on right side. Nothing is loose on engine, rattle does not increase upon acceleration from what I can tell. I used NON Ethanol Gas. Could it be pre-ignition. I will remove from drive belt to see if its a pulley. pull plugs ETC. Probably pull right valve cover as last resort. All and any input appreciated.
Ron
Ron
