A/C Install Cost
jasonmcc
Nola -> Utah
Does anybody have a rough estimate of what a man could expect to pay in labor cost for a vintage air a/c install in a coyote bronco?
steelefx4
Newbie
Depends on your location and the going hourly shop rate.
Cheapest where I'm at is $65/hr...minimum 6hrs for the install, more likely 8, so that's over $500, then another $150+ to charge the system.
Do you have the compressor already on the Engine?
-Jake
73azbronco
Unless it's a specialty shop working on old cars, I doubt anyone would take the job, it's not book.
You are up in Kindig territory, call them and ask for other shops, Kindig is booked years out.
steelefx4
Newbie
And that. I don't think i'd trust just any shop to work on a Bronco with a Coyote in it.
JeepGuy
Pretty sure Vintage Air in these Bronco's was called rolling the windows down or taking the doors and top off.:)
I know I know... someone had to say it.
Madgyver
Bronco Madman
Given that all parts are available for the task, I'd say it's an all day job just with a fresh build without a dash in place. at $100.+ per hour plus charge rate for R134A at say $200. that's over 1K. and then you get shop charges and taxes. Ask around and you'll probably get 2k to 3k quotes, and that would be considered cheap at specialty shops..
I would be scared of any shop that would do it for under $1k. Either giving there time away or be prepared for a hack job.
Do you even have a place for an A/C compressor? Often the compressor is removed to install a power steering pump. Now there is a LOT more work. Special (and somewhat expensive) brackets. Convert to electric power steering pump. The Coyote factor really adds to the work and parts involved over a conventional small block A/C install.
So not only 4-figure price, but deep into that 4-figure price.
sprdv1
REBEL
Definitely do the research in your area for shops, and best price/reputation
cannunz546
Bronco Owner and Admirer
Northwest Suburbs, Chicago
I am in the Chicago area and had an old school top notch mechanic hand build an entire new A/C system. I have not looked at the invoices in a while but I believe the total time was about 40 hours (60/hr) and parts ran about 1500 to 2k.
bigmex
Newbie
Depends of your location, in Austin I got a quotes from 1k to 2k for labor (depending under dash, in dash, hiding hoses, etc)
Madgyver
Bronco Madman
I got quoted for an OEM AC replacement at a dealer for another vehicle and it was over $5K. and this is only a "remove and replacement" of the evaporator unit.
